removing seats from a 98 civic dx to clean carpet
Old Apr 16, 2006 | 12:17 PM
veggiegrrrl's Avatar
veggiegrrrl
Default removing seats from a 98 civic dx to clean carpet
hi everyone,
i'm a grrrl with no car experience but my carpets are filthy gross. there is long hair (mine) embedded in the seat sliders, etc.
how can i remove the front seats from a 98 civic dx to clean carpet?
what tools do i need? is it easy? hard? thanks!
amy
Old Apr 16, 2006 | 12:29 PM
randomtask77's Avatar
randomtask77
Wanderer
There are four I think 10mm sized bolts that hold each of the front seats down. The two on the front should be pretty obvious and the two in the back might be covered by a plastic trim (it'll be easier to unbolt if you slide the seat forward). The driver side seat is going to have a little cord attached to the bottom of the seat that you'll have to unclip before you could remove it (passenger side doesn't have it).
Old Apr 16, 2006 | 09:10 PM
i think its just a 10mm... 4 of them as stated...,.. two up front and 2 in the back.... with a plug for a sensor right under so dont yank it out out right away.
EDIT: reading ownz me random is right on the dot with everything h:
Old Apr 16, 2006 | 10:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
They are 12mm bolts.
Old Apr 17, 2006 | 07:34 AM
cyang08's Avatar
cyang08
yup they are 12 cause i know i had to remove my old seats to put in 99si seats. its pretty easy. remove bolts, take out seats, clean how you like, put seats back in plug up sensor, rebolt and boom your good to go. wish i would have cleaned my car when i took my seats out too. o well to lazy to do it again. oh and if you can't lift the seats then have a brother or boyfriend take the seat out.
Old Apr 17, 2006 | 09:26 AM
eonsx311's Avatar
eonsx311
today is not my birthday.
Originally Posted by veggiegrrrl
hi everyone,
amy
i need to do this too. my gf's hair is all in that shit too. plus when ever i drop somthing down there i rarely can fit my hand down there to get it so whoooo knows what is lurking....
Old Apr 18, 2006 | 05:51 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
dont forget to unplug the seatbelt alarm wire on the drivers side seat before trying to pull it out.
