speedometer not working help...
Old Apr 12, 2006 | 11:34 PM
neil_337's Avatar
neil_337
Default speedometer not working help...
okay just a few weeks ago the speedometer on my honda civic cx hatchback was acting funny.it was going up and down and now its dead.I took the cluster out and check for any loose wire but none and now i'm stuck.please help.
Old Apr 12, 2006 | 11:38 PM
91tegB18c3's Avatar
91tegB18c3
check your speed sensor on top of your tranny...
Old Apr 13, 2006 | 04:15 AM
Wharbone's Avatar
Wharbone
:werd: Check your VSS
Old Apr 14, 2006 | 08:00 PM
m735is's Avatar
m735is
I had that happen a few years ago. The VSS wasn't the cause, I swapped the cluster because I had another. About a year later it bounced again. I was going to swap this cluster with another, but when I was removing my ground strap from the battery it was very oxidized, so I cleaned it up. Fine since.
I haven't tried swapping the original cluster back in to see if it was actually a bad ground because my current one still works fine, so I can't be sure if it was from the ground or not. Just a long winded suggestion I guess.
Short version: clean ground points, check speed sensor, swap cluster.
It could have something to do with the dimmer switch also, seems like everything electrical on the dash is affected by that sucker. Then a couple turns of the dial and it settles down again (third switch).
Old Jun 8, 2006 | 01:35 PM
peter1023's Avatar
peter1023
Default The circuit board in the cluster might be the issue
I have read that others who have seen this problem occur in their cars have actually swapped the circuit board that is a part of the instrument cluster. I am having the same issue with my speedometer right now and am looking for a solution...anyone know if you can order the circuit board separately from the cluster?
Old Jun 9, 2006 | 08:36 AM
tommyhcky13's Avatar
tommyhcky13
you casn prolly get it but it will be expensive. i changed the whole thing out and mine started working again
Old Jun 23, 2006 | 02:03 PM
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
hey neil 337. So did you ever fix the problem. If you did, what was it?
Old Jul 11, 2006 | 07:59 PM
ceagan's Avatar
ceagan
'94 Civic EX SOHC VTEC
I am having a similar problem with my '94 civic. The battery light comes on occasionally and flickers. The speedometer bounces occasionally as well.
What exactly are you referring to by the "ground strap from the battery?" Is this the ground connection on the battery?
I am hoping to resolve this without buying a new speedometer (as the dealer suggested as the problem.)
