So I went to Pep Boys!!!!
Could someone help me out here?
I went to Pep Boys to get my engine codes read it turns out ( as they say) that I have a faulty po6 computer it'll cost 793 directly form the dealer to get one. My question is could this faulty computer cause my number 4 fuel injector, o2 sensor, and map sensor to go hay wire? I think they where trying to pull a fast one on me and my wife can someone help me????
A P06 should cost you a little less than $100, if that's your problem. You might wanna elaborate on the problem a little more, so the guru's can tell you what might be going on. Also, check the classifieds here. Someone should be able to hook you up.
If the problem IS the ECU, try ebay and buy from someone who sells them often and has good feedback and replacement warranty.
warm butter on toast
No way in hell should it cost almost 800$. More like 100$. Go someplace else to have your codes read or you can learn to do it yourself at the resources sticky at the top op this forum.
A faulty ECU will cause some sensors to function improperly...change the ECU and see what happens...1st of all what year and what model
Rachel Bilson
Originally Posted by pghprettie_boi
92 civic lx
____ (long flash = 10)
__ (short flash = 1)
