HELP: finding a wire
Old Mar 30, 2006 | 12:33 PM
cilvia's Avatar
cilvia
Default HELP: finding a wire
where can i find the wire/s that make the guages and signal lights blink when you arm or disarm the car?? because what i wanna try and do is tap it where my dome lights will blink with the signal and gauges...anyone can help me do this?? its for a 97 civic thanks
Old Mar 30, 2006 | 11:02 PM
cilvia's Avatar
cilvia
Old Mar 31, 2006 | 02:43 AM
ReVenGe's Avatar
ReVenGe
if you have the manual to your alarm you can find out which wire on the brain it is and just use that one so you dont have to find all of them.
Old Mar 31, 2006 | 11:06 AM
cilvia's Avatar
cilvia
yea i actually had a paper that shown the wires but lost it... ...would you happen to kno which one it is?? thanks
Old Mar 31, 2006 | 11:38 AM
ReVenGe's Avatar
ReVenGe
wel..... i dont know what alarm you have ;p
and no
Old Mar 31, 2006 | 11:40 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
On mine it is the #19 fuse and I believe it is a white/red wire coming out the back of the fuse block. Check the fuse block to confirm.
Old Mar 31, 2006 | 12:19 PM
cilvia's Avatar
cilvia
sorry i got a clifford rsx 3.5...someone also told me i would need to put a relay cause the brake lights use 12v and the dome light uses ground or somethin...iono...how would i go bout doin these two once i figure which wires?? i cant just connect the green wire from the dome to the brake lights??
Old Mar 31, 2006 | 03:09 PM
ReVenGe's Avatar
ReVenGe
yeah... i didnt actualy thing about the fuse box.. you could shove a wire down in there too
Old Mar 31, 2006 | 03:16 PM
Provocateur
On permanent hiatus
Not shove a wire in, but find the wire that goes to that specific fuse (since the parking and running lights are on the same fuse) and then splice the wire into it.
Old Apr 4, 2006 | 10:52 PM
cilvia's Avatar
cilvia
what about a relay?? would i need one of them?? and what are they used for??
