How the hell can these be related??
warm butter on toast
Ok, this may take a little while to explain. Over the course of last summer and last winter my car would either stay at a good temperature and always start or it would overheat and it would need to be pop started. Today it got a little hot, it didn't over heat but I got home and shut my car off. I was just about to go out and my car wouldn't start. This is the imfamous starting problem I've made numerous threads about. So I said fuck it and jumped my clutch position switch and my car starts. How can my car overheating be related to my clutch position switch giving out? Their either related or it's a coincidence that occurs 100% of the time my car overheats. After about 9 months, countless hours, new ground wires, countless radiator parts and a new starter I finally figured out it's my clutch position switch that has been giving out. But why is it only when my car overheats?
thats realy weird..... i dont know enouh about the whole clutch starter poistion checker thingy............
but that ive tested it on my car and its not the same every time...
i test it by turnin on the car and then slowly pressing down the clutch untill the starter will go.
There are 2 sensors on the clutch. It's pretty much a simple push button. One is triggered when the clutch is pushed in and the other is triggered when the clutch isn't pushed in. If you jump the sensor for it being pushed in you can start your car without having to push in the clutch. After I did so, the car started. I'm completely fuckin' stumped as to why it only does that when my car goes over 1/3 temp. I could have saved a lot of money if I had just jumped it last summer like someone said.
Originally Posted by Fkatz
where is this sensor located at many sensors don't work correctly when they get hot sensors are very touchy remeber that
Rachel Bilson
You should seriously fix the overheating issue because your engine isnt gonna last much longer.
Originally Posted by jeterkm02
have you noticed any correlation between the engine temp and having the heat on inside the car? did you bleed the coolant to make sure no air is in there?
