SHOCKing question
Old Mar 28, 2006 | 04:56 PM
cyang08's Avatar
cyang08
Default SHOCKing question
i am gona be using 99 honda civic SI shocks on my 94 dx coupe. i need to buy new bushing cause my bushing bolt and bushing became one. and it seems as if my stock bushing on my dx wont work with my 99 si shocks. i havent got the new bushing yet. i was woundering if i use a 99 si bushing, will it fit on my 94 dx control arm???? i hope you guys understand what im saying. but yea i could use some help. Thanx
Old Mar 28, 2006 | 05:33 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Why would you put newer shocks from a different generation of car onto an older gen....Umm if im correct its not gonna work.
Old Mar 28, 2006 | 05:42 PM
i dont understand what ur saying h:
but i think ur asking if Ek shocks will fit on EG/EJ.... yes it does h:
Old Mar 28, 2006 | 05:53 PM
cyang08's Avatar
cyang08
first off i broke the bushing bolt while trying to put in lowering springs. then i found that there was no way of removing the rest of the bolt. so i was f*** it ill just cut the bottom of my shock mount to get the shock off. now i have to get a new bushing. the thick inner sleeve of the bushing looks as if it is to big and the 99 si shock mount wont fit. well if i just get a 99 si BUSHING. then will the 99 si shock fit, and will the 99 si bushing even fit into the whole on my 94 civic control arm??? the reason im putting 99 civic shocks on my car is i dont have any more 94 civic shocks and this is for temp only.
Old Apr 3, 2006 | 03:10 PM
orbit77's Avatar
orbit77
i'm not for sure but i think that the 99 shocks are thinner than the 94 shocks.
Old Apr 4, 2006 | 12:40 AM
thecarguy's Avatar
thecarguy
Your springs aren't goin to fit on the struts properly, or you are going to blow them because of the wrong application. Not too sure if it will work, but if you get it to work, good shiot. Good luck.
Old Apr 4, 2006 | 10:53 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
I would think that it would be a harsh ride cause of the em1 shocks are meant for a car hat weighs more. I just picked up a set of brand new kyb AGX for my 99' si for 300 shipped. So that is another option is just to spend an extra buck and upgrade for what is right for vehicle.
