turbo masters need your help
I just go myself a garret t3/t4 turbo I'm trying to drop in into my 94 si. I am farly new to the turbo aspect of cars seenin how im the first guy out of my friend to have one. so my question is am i able to take my tubo apart and rotate the sectoins of it to make it blow in the direction i need. right now the turbine that makes boost is blowing up when i need it to blow down. and the oil feed it on the top.
Your Powder Coater
agreed, you can loosen the bolts on the housings, which will allow you to turn them to face which ever direction you would like. Be sure to snug them up nice & tight when your done so that there aren't any leaks.
sometimes i loosen everything, put it on the engine & adjust it to face the exact spot there.. then tighten one bolt to hold it in place, pull it off the engine & tighten the rest. It's much easier to make it all the way around the housing while it's not on the engine. best of luck to ya.
