what the crap
Old Mar 18, 2006 | 09:24 PM
Wreckless96's Avatar
Wreckless96
Default what the crap
i have a 94 civic si
my car revs all on it own untill it warms up. then it goes away. anybody else have or had that problem. if so what was wrong with it
Old Mar 19, 2006 | 07:00 PM
Secondhandloser's Avatar
Secondhandloser
it is how the car warms the engine up faster. its a good thing.
Old Mar 19, 2006 | 07:21 PM
Omniscient's Avatar
Omniscient
warm butter on toast
What the fuck? No fucking way! It's your FITV dude. Fast Idle Thermal Valve. It's located underneath the throttlebody and has a coolant hose connected to it. It's held in place by 3 10mm bolts. Remove these bolts. You can leave the coolant line attached so you don't lose much. On the back of the FITV there's a copper looking cap held on by 2 8mmbolts. Remove these bolts and you'll see a plunger threaded inside of the FITV housing. Use your fingernails or a flathead screw driver and thread the plunger in as far as you can untill you feel resistance. Make sure it's all the way in or it can and probably will wriggle it's way back out. Re-assemble the way you took it apart.
Old Mar 19, 2006 | 07:30 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
HAHAHAHA...What are the forums becoming
Old Mar 19, 2006 | 08:55 PM
Omniscient's Avatar
Omniscient
Uneducated questions are one thing, but when people start giving out information like that...
Old Mar 19, 2006 | 10:53 PM
Wreckless96
thank people. and secondhandloser your a dumb shit
Old Mar 19, 2006 | 11:03 PM
90CvcDX's Avatar
90CvcDX
kekeke
haha pwned. thanks for the info though i had this problem too now i can fix it
Old Mar 20, 2006 | 02:13 AM
Kai's Avatar
Kai
Rotorphile.
This often happens when the coolant level is low. Check the radiator and overflow tank first, then move on to more complicated toubleshooting procedures.
Old Mar 20, 2006 | 12:27 PM
bnuk's Avatar
bnuk
well, the idle is higher when the engine is cold, but only like a couple hudred RPM.
Old Mar 20, 2006 | 12:33 PM
Wreckless96
in it rev to 2500 and then drops to 1200 and revs back up again its an annoying prosses and the only thing that i can do to keep my sanity is press on the gas so that it doesn't do it.
