Help Plz
Old Mar 9, 2006 | 09:03 PM
92HondaHatch's Avatar
92HondaHatch
Default Help Plz
I recently purchased a 92 Honda Civic Hatchback and am having problem with the lights. First off everytime i turn the highbeams on, my passenger side headlight shuts off. second when i turn the right blinker on the lights dim and they only work when the hazard is on. Oh and the instrument panel lights dont work at all and i've checked the bulbs and they are all good, and have also checked all the fuses. anyone that can help plz write back
Old Mar 10, 2006 | 12:32 AM
NOSkweezePSI's Avatar
NOSkweezePSI
If had access to a DVOM you should check to see if your gauge cluster is getting power. If not, trace the wires back to fuse box as best as you can. You might have a short somewhere down the line. If you can't find anything wrong, check your grounds for and breaks. When it comes to the headlights the only thing I can think of is some kind of short in the high beam wire or possibly a bad relay. Maybe you have mice chewing on your wires. When you are examining your wiring, check for little turds. When it comes to your turn signal, sounds like you have high resistance. Clean all your terminals of any corrosion. Wouldn't be too surprised considering that its the end of winter assuming that you are from a state that actually gets snow. .
Old Mar 10, 2006 | 12:44 AM
Kai's Avatar
Kai
Rotorphile.
I would say that your passenger's side high beam is burnt out.
Aside from that, you have some serious wiring issues. I need access to wiring diagrams to help you from here (which I have, but that computer is down. )
