My money pit has a new problem.
Old Mar 8, 2006 | 03:14 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Default My money pit has a new problem.
Symptoms.
Monday, normal idle 700-900 rpm with that eratic rpm jumping up to about 1,500 rpm.
Tuesday, high idle about 1,500 rpm with no eratic jumping of the rpm.
Wednesday, high idle about 1,500 rpm with eratic jumping up to about 2,500 rpm.
I know I'm supposed to carb clean some valve but I don't remember if it's the fast idle thermal valve or the IACV. I'll also fool around with a flat head and adjust that screw and see what that can do for me. I just forgot what valve I'm supposed to carb clean so I said fuck searching.
Old Mar 8, 2006 | 04:24 PM
Omniscient's Avatar
Omniscient
Well, it only does it at operating temperature so it looks like it's probably the IACV.
What would cause my high idle?
Old Mar 8, 2006 | 04:35 PM
CaliDELSOL93si's Avatar
CaliDELSOL93si
IACV :af:
high idle ? hmmm...good question, don't know
Old Mar 8, 2006 | 06:03 PM
Wharbone's Avatar
Wharbone
To test your fast idle valve, take off your intake. There is a hole on the inside of the throttle body.
When your car is cold, there should be suction at that hole. Put your finger over the hole to check. When your car is warmed up, there shouldn't be any suction. If there is, you need to either buy a new one or screw in the plunger.
You would use brake/carb cleaner on your IACV screens if they are gunked up.
Old Mar 8, 2006 | 06:57 PM
Omniscient's Avatar
Omniscient
I've read a bunch of searches and almost everyone said the FITV was when it's cold and still warming up. During that time it stay at about 2,200 rpm and when it warms up it drops to 1,500 now and does the eratic jumping.
Old Mar 9, 2006 | 03:39 AM
Wharbone's Avatar
Wharbone
I would still check the FITV. It is really easy.
Also, check for vac leaks.
Old Mar 10, 2006 | 11:33 AM
Omniscient's Avatar
Omniscient
I checked my FITV. The plunger was completly unthreaded from inside the FITV. I just used my fingernails in the two slots to rethread it back in and problem solved. Very, very smooth idle now. Better than it's ever been. It took about 1/2 to take it off, clean it, rethread it and put it back on.
Old Mar 10, 2006 | 11:50 AM
Running925's Avatar
Running925
Your Powder Coater
just an idea.. but u'r TPS could be going bad as well.. check the wires with a volt meter.. should range from 0.5 to 5.5 volts
Old Mar 10, 2006 | 01:20 PM
Wharbone's Avatar
Wharbone
Glad you got it fixed man! I thought it was probably your FITV
