Knock Sensor?
Old Mar 2, 2006 | 06:31 PM
DELSOL98GSR's Avatar
DELSOL98GSR
Default Knock Sensor?
What would happen if you tried to start your engine without the knock sensor plugged in? Let me know thanks..
Old Mar 2, 2006 | 06:42 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
When knocking occurs, the weight in the cylinder case moves, causing the piezo electric element in the KS to translate the vibration into an electric voltage. A signal is then transmitted from the KS to the ECU. In response, the control unit retards spark timing to prevent engine knocking.
Old Mar 2, 2006 | 07:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It would throw a CEL about 50 feet down the road. Other than that, nothing.
Old Mar 2, 2006 | 09:17 PM
DELSOL98GSR
trying to figure out whats wrong..
had head all re done , new valves, seals, springs, etc.. neways got it all back together. when i try n start it, it backfires..
only thing i know thats not on is the knock sensor. i didnt think itd matter right now..
Only other thing i can think of is that when i set the timing that i have the TDC set on the exaust stroke not the intake stroke? what do u guys think?
Going to check the disp cap tomorrow. make sure the lil rotor isnt broke or nething, let me know thanks
Old Mar 2, 2006 | 09:36 PM
Provocateur
On permanent hiatus
Recheck the cam and ignition timing. A knock sensor out of place would not cause a backfiring, but you should put it in anyway to get rid of the check engine light.
Old Mar 2, 2006 | 09:50 PM
DELSOL98GSR
ignition timing hasnt changed. and timin marks seem to b linged up might b off 1 tooth..
Old Mar 2, 2006 | 10:03 PM
RSXt3's Avatar
RSXt3
if its backfiring sounds like the engine timing is off
Old Mar 2, 2006 | 10:09 PM
DELSOL98GSR
it turns over fine, got fuel n everything when it kicks (tries to start) it backfires, even some flame out the throttle body.. any suggestions
