Locking differentials
Old Mar 1, 2006 | 05:42 PM
its not anS2000's Avatar
its not anS2000
Default Locking differentials
do they make locking differentials for hondas? im sorta new to the honda thing. also i have a safc and what size infectors do you recommend for a none turbo hatch with a b16 swap?
Old Mar 2, 2006 | 12:48 AM
NOSkweezePSI's Avatar
NOSkweezePSI
Umm, locking differentials are for going off-road and rock crawling. You are probably thinking of an Limited Slip Differential (LSD) which will engage both drive wheels rather than creating a one wheel burn out. LSDs are available through several manufactures. As far as the injector question goes, if you are non-turbo then factory should be quite sufficient. If you are not sure, you could always visit RC Engineering website (www.rceng.com) and use their formula to figure out the optimal injector size for your applicaton.
Old Mar 2, 2006 | 07:25 AM
its not anS2000
Default lsd
wil this lsd give me more horse power traction wise?
Old Mar 2, 2006 | 08:21 AM
ewood87's Avatar
ewood87
Eric Wood
...it will allow you to put the horsepower down to the ground and make use of it in the low gears/corners.
Old Mar 2, 2006 | 09:13 AM
raiden571's Avatar
raiden571
turning u inside out
afc and injectors are a waste. if i were going with an lsd id either get a quafie or the obx style one. the obx is actually very nice for the price and if the honda-tech nazis dont have much bad to say about it, what the hell.
i would turbo the bitch too. i wouldnt dick around with an NA b16, not worth it in my opinion.
