96 Civic.....Missing Under a Load
Old Feb 21, 2006 | 05:31 PM
2.4R/T's Avatar
2.4R/T
Default 96 Civic.....Missing Under a Load
96 Civic EX D16Y7
I bought the car with 160k on it last year with the same miss. I did a full tune-up including plugs, wires, cap, rotor, fuel filter, O2 sensor and it fixed the problem. Last week(200k) the car developed the same miss, only under a medium to heavy load but never misses at idle. I again changed the plugs, wires, cap and rotor but the miss is still there. The inside of the cap was dry and the plugs were a light tan with no visable wear. I have no CEL and the problem will disapear for a day and then return the next. It does seem to be getting more persistent. Temperature and moisture does not seem to affect it and I have run the tank low and refilled+fuel injection cleaner since the problem started.
Does anyone have any suggestions. I would figure that if a sensor was bad I would certainly have a CEL. I would also figure that if it was a fuel filter/injector issue the ecm would compensate and the plugs would be dark.(I think) If the timing was off I would have a consistent problem and not sporadic. This leaves the coil to contend with. How often do these fail, would this cause my issue?
I would appreciate any help or suggestions!
Kevin
Old Feb 21, 2006 | 05:37 PM
'98 EX RED's Avatar
'98 EX RED
King of the Auto Civic
Are you sure it has a d16y7 and not a y8?
Old Feb 21, 2006 | 06:10 PM
2.4R/T's Avatar
2.4R/T
You may be right, been a while since I looked at it.
Old Feb 22, 2006 | 03:29 AM
extensioncordy's Avatar
extensioncordy
EG6
my car ran rough and i replaced my fuel filter... it helped alot then a month later it was doing it again and i replaced my injectors and no problems since. you might want to replace the fuel filter for the hell of it seeing as it has 200k+ miles
Old Feb 22, 2006 | 06:34 AM
'98 EX RED's Avatar
'98 EX RED
Yeah, its a 5 min job and under $25.
Old Feb 22, 2006 | 07:38 AM
2.4R/T's Avatar
2.4R/T
Do you think it could be clogged that quickly? I do kinda run it low sometimes so it might be picking up dirt off the bottom of the tank. I will try the fuel filter tonite.
