changing drums to disc
Old Feb 17, 2006 | 01:05 PM
crkt_rcr's Avatar
crkt_rcr
Default changing drums to disc
I'm planning to change my wife's rear drum brakes into disk brakes. I have a pair of dc rear trailing arms with disk brakes & steel braded brakes lines , when i change this , do i have to change the proportion valve , by the way my wife's car is a 00 ex coupe
Old Feb 17, 2006 | 01:13 PM
CivicRacr's Avatar
CivicRacr
you could use the proportioning valve from a 99-00 civic si, direct bolt-on and dont have to rebend the hard lines
Old Feb 17, 2006 | 05:05 PM
CaliDELSOL93si's Avatar
CaliDELSOL93si
prop valve should be a 4040
Old Feb 19, 2006 | 01:35 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
you don't have to replace the prop vavle for it to work, but brake distribution will be a little better if you do replace it. Honestly, the difference will be hard to notice except under simultaneous hard braking and cornering. Any vavle marked 4040 (crx si, 2nd/3rd gen integra, some Del Slo, EXs and Si) will do the trick.
Old Feb 19, 2006 | 01:41 PM
Civic2Scooby's Avatar
Civic2Scooby
you dont need to change the prop valve what so ever...search for the article on here or honda-tech about the design and implication of the prop valves...you will not need to replace it, your drum one will work just fine.
