Online Resources - Updated 2/14/06
First and foremost, Civics and Integras have ONE HEAD|ER|. Header(s) refers to multiple whereas these vehicles only use one headER due to the design of the exhaust manifold. Please, keep this in mind.
Research Information
www.howstuffworks.com
Manuals & Parts Catalogs
Various Helms Manuals: http://www.redpepperracing.com/technical/main.php
94 Integra Helms Manual: http://tech.hybridgarage.com/tech/ma...e%20manual.pdf
Parts Catalogs & Manuals: http://icelord.net/honda/repair/
Electrical
5th gen Civic underhood fuse diagram: http://spoon.org/civic/pics/93-Civic-Fuse-Block-2.jpg
5th gen Civic interior fuse diagram: http://spoon.org/civic/pics/Interior-Fuse-Panel.jpg
5th gen Civic fuse legend: http://spoon.org/civic/pics/93-Civic-Fuse-Block-1.jpg
Check your Check Engine Light (CEL): https://www.honda-acura.net/forums/s...d.php?t=185065
Check Engine Light (CEL), what do I do?: http://www.c-speedracing.com/faq/03.php
Check your Check Engine Light (CEL): http://www.c-speedracing.com/faq/06.php
Define your Check Engine Light (CEL): http://www.c-speedracing.com/faq/05.php
Resetting DelSol's ECU: http://www.austrosol.com/tips/reset_ecu_eng.htm
Engine & Tuning & Cooling
Skunk2 B18C1 intake manifold DIY (it's not just a bolt-on mod, the TB bracket will hit your hood if you don't follow these instructions): http://www.ff-squad.com/tech/howto/sk2manifold/
Skunk2 B18C1 intake manifold & Hondata intake gasket DIY: http://repo.jackmoves.com/v/erik/alb...m129/album215/
96-2k Greddy oil catch can install (NA/FI): http://repo.jackmoves.com/v/erik/alb...m129/album130/
96-2k Integra radiator swap (doesnt retain AC): http://repo.jackmoves.com/v/erik/alb...bun03/albun46/
Bseries STR Cam Seal Install: http://repo.jackmoves.com/v/erik/alb...m157/album159/
Bseries Skunk2 Cam Gear Install: http://repo.jackmoves.com/v/erik/alb...m157/album158/
DelSol home made air duct: http://www.impactsites2000.com/autozone/delsolmod_2.htm
Clutch/Flywheel replacement: https://www.honda-acura.net/forums/s....php?p=1715569
---:Forced Induction (FI) Related:---
Turbocharging basics - LOTS of information: http://www.beesandgoats.com/boostfaq/g2icturbo.html
DIY Boost Controllers: http://www.c-speedracing.com/howto/mbc/mbc.php
Another DIY Boost Controller: http://www.geocities.com/chmwatson/FAQs/mbc.html
Basic Maintenance
Axle Replacement: https://www.honda-acura.net/forums/s...d.php?t=173647
Clutch/Flywheel replacement:https://www.honda-acura.net/forums/s....php?p=1715569
Fuel pump replacement:https://www.honda-acura.net/forums/s....php?p=2337636
How to Change DelSol Spark Plugs: http://www.impactsites2000.com/autozone/delsolmod_1.htm
Civic/Teg - Changing front & rear disc brake pads and rotors: http://www.g2ic.com/tegtips/brakesus/5.html
Drivetrain
15 minute axle replacement: https://www.honda-acura.net/forums/sh...d.php?t=173647
Clutch/Flywheel upgrade DIY: https://www.honda-acura.net/forums/sh....php?p=1715569
Bseries tranny specs: http://www.bseries.net/html/specs/btrannyspecs.php
Hybrid
92-95 Civic B18C1 swap: http://www.c-speedracing.com/howto/b18cswap/swap.php
96-2k B18C swap: http://repo.jackmoves.com/v/erik/alb...bun03/albun45/
Kseries into 92-95 Civic, 94-97 Sol, 94-01 Teg: http://www.k20a.org/EGK1.pdf
Kseries into EK: http://www.k20a.org/EKK1.pdf
Brakes & Suspension
Omni Power Camber Kit:https://www.honda-acura.net/forums/s...79#post2209279
Rear Camber Adjustment (Cheaper than a Kit): http://home.earthlink.net/~civicex95/rearcamber.html
96-2k rear integra disc brake swap: http://repo.jackmoves.com/v/erik/album53/album55/
96-2k Power steering and swaybar conversion: http://repo.jackmoves.com/v/erik/album106/album119/
ITR master cylinder swap: https://www.honda-acura.net/forums/s...d.php?t=134103
Exterior
DIY for fitting H4 HID's in an H4h housing: http://www.turntableteknicianz.com/carpics/TL%20HID.htm (if you can get a D2R/S bulb)
Difference between H4 and H4h:
http://oregonstate.edu/~blackry/pic...s/h4andh4h3.jpg
http://oregonstate.edu/~blackry/pic...s/h4andh4h2.jpg
http://oregonstate.edu/~blackry/pic...rs/h4andh4h.jpg
(H4h is the smaller/shorter bulb)
'96-'98 Civic all OEM power window converstion: http://repo.jackmoves.com/v/erik/album106/album206/
92-95 power window/mirror/lock conversion: http://repo.jackmoves.com/v/erik/albun31/albun42/
99-00 Si Lip Install on EG: http://www.jdmvtec.com/silipinstall.html
92-95 to 96-2k mirror conversion: http://repo.jackmoves.com/v/erik/albun31/album104/
99-2k Grille removal (realy simple): http://repo.jackmoves.com/v/erik/alb...m129/album146/
Painting your headlight housing:https://www.honda-acura.net/forums/s...ad.php?t=56277
Interior
Integra GSR Cluster in EG: http://www.geocities.com/cinq112/gsrclusterswap.html
GSR cluster into civic wiring diagram: https://www.honda-acura.net/forums/a...id=51278&stc=1
6th Gen gauge cluster swap - entire cluster swapped: http://repo.jackmoves.com/v/erik/alb...m138/album161/
96-2000 detachable steering wheel install with SRS disable: http://repo.jackmoves.com/v/erik/alb...un41/album244/
96-98 Civic Dash swap to 99-00: http://repo.jackmoves.com/v/erik/album106/album228/
Security
Fuel Pump Cutoff Switch: http://www.teamdelsolwa.com/howto/fuelcutoff.htm
96-00 Hood Lock Installation: http://repo.jackmoves.com/v/erik/alb...m268/album269/
Misc & Large Listings
Numerous Del Sol How-Tos: http://www.teamdelsolwa.com/howto.html
Many excellent engine/suspension/fuel/etc. DIYs: http://www.c-speedracing.com/howto.php
DelSol Technical Specifications: http://members.lycos.nl/hendrik/delsol/soltech.htm
Many, many important resources: http://www.hondaswap.com/forums/index.php?showforum=33
96-2k complete front subframe swap/repair: http://repo.jackmoves.com/v/erik/album106/album139/
Bunch of great DIYs: http://repo.jackmoves.com/
HAZONE various DIYs: http://www.hazone.com/hhowto.htm
HONDA's own DIY install instructions: http://www.hondaautomotiveparts.com/instal/instal.htm
Spectacular set of articles here (includes N/A B20 build-up, engine building tips, and more): http://www.theoldone.com/articles/
KILLER ECU Info: http://ecu.ff-squad.com/info.htm
More Tech Info than you can shake a stick at: http://technet.ff-squad.com/
D and B series engine specifications: http://hybrid2.honda-perf.org/tech/engine.html & http://www.bseries.net/html/specs/benginespecs.php (Bseries only)
Wheel offset info:https://www.honda-acura.net/forums/s...50&postcount=2
PM me if you have any updates or if you need a place to host your own how-to
Electrical
Basic Maintenance
Drivetrain
Hybrid
Brakes & Suspension
Exterior
Interior
Security
I have stickied this temporarily. The old thread is staying stuck as well until I have time to go through and ensure that all the essentials of the old thread are here. I have already made some changes of my own, such as the removal of a couple of links and the removal of the "naturally aspirated" section title as it made no sense.
This thread will remain unlocked - also temporarily. Posts may be made about things that should be added, removed, or changed. Anyone who whores, derails, or is otherwise a moron in this thread will recieve some serious warning points.
