What is the biggest wheel radius...
Old Feb 9, 2006 | 05:46 PM
remy's Avatar
remy
Default What is the biggest wheel radius...
i can put onto a 97 honda civic coupe without having to drop it or make any modifications to the suspension system of the car?
I heard that mounting 16 inch wheels and/or bigger one has to drop the car in order not to damage the suspension system...is this true?
thanks!
Old Feb 9, 2006 | 07:25 PM
randomtask77's Avatar
randomtask77
Wanderer
You can put any size wheel you want granted the wheel well would allow it. As for lowering the car... Not really necessary, but I do find adding a bigger wheel/tire setup looks kinda funny without a drop.
If you want to add a larger wheel/tire setup than stock but still want to have a near stock ride characteristics, I'd recommend a 16x7" wheel with a +40mm offset mated with 205/45/16 tires.
Old Feb 10, 2006 | 01:54 PM
remy's Avatar
remy
thanks for the info!
appreciated!
Old Feb 12, 2006 | 11:32 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
And it's not radius it's diameter unless you like 1/2 a wheel
Autocross Help Page
Old Feb 12, 2006 | 03:51 PM
jdm90civic's Avatar
jdm90civic
actually the largest wheel recommended for most hondas is 16 inchs and its not the suspension that is effected by this it is the wheel bearings!
Old Feb 12, 2006 | 05:54 PM
jskoots83's Avatar
jskoots83
Would this apply to 2004 Civic EX? I just recently purchased 17s... what kind of effects do you speak of? Thanks.
Old Feb 13, 2006 | 05:24 AM
remy's Avatar
remy
will 16" rims affect the wheel's bearings??
Old Feb 13, 2006 | 02:16 PM
CivicSiRacer
Any wheel heavier than stock will negatively affect suspension components, brakes, and wheel bearings.
Autocross Help Page
Old Feb 13, 2006 | 04:52 PM
remy's Avatar
remy
so u are saying that by putting in any kind of wheels to the car, one has to mess/change/replace the suspension system and/or wheel bearings??
Old Feb 13, 2006 | 05:47 PM
CivicSiRacer
no. But it/should wear out those pieces quicker than if you ran a stock setup. But stock is boring.
Autocross Help Page
