G28r Turbo, Do i need to change fuel system when installing a turbo system?
Old Feb 1, 2006 | 12:30 AM
Dime333's Avatar
Dime333
Default G28r Turbo, Do i need to change fuel system when installing a turbo system?
I found a Garret turbo kit i like, do i have to change the fuel syste, i.e., injectors and pump...if so what should i change them to?
Old Feb 1, 2006 | 01:27 AM
waaBAAH's Avatar
waaBAAH
how much boost you planning on?
Old Feb 1, 2006 | 01:40 AM
Dime333's Avatar
Dime333
Stock Garrett Turbo Kit HP 109whp @ 6600rpm 176whp @ 6850rpm Torque 95lbf· ft @ 5100rpm 140lbf· ft @ 5400rpm
1. Honda Civic
SOHC D16Y8
The Garrett Honda Civic kit is for the D16Y8 SOHC engine for model years 1996-2000. A GT28R ball bearing turbocharger and all of the necessary components are included to complete the installation in your garage!
  • Emissions certified in all 50 States
  • Model years 1996-2000
  • GT28R Turbo
  • Garrett exclusive ball bearing turbo for unbeatable response, efficiency, and durability. Absence of a thrust bearing eliminates failures at elevated boost levels
  • The most complete kit on the market
  • Includes everything you need to install; Intake Manifold, Intercooler, TiAl Blow-off valve, Ni-Resist exhaust manifold, turbo-link piggyback ECU
  • Was $3,778.95
Old Feb 1, 2006 | 01:46 AM
waaBAAH's Avatar
waaBAAH
like i said...how much boost you plan on running?
Old Feb 1, 2006 | 04:25 AM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
regardless of boost, yes upgrade your injectors and fuel pump.
Old Feb 1, 2006 | 05:09 AM
waaBAAH's Avatar
waaBAAH
great...now his next question is going to be...what should i run for fuel pump and injectors....and then my response will be....HOW MUCH BOOST YOU PLAN ON RUNNING. if he is only going to run about 5 (i even think up to 8 is ok) he really doesnt need to change anything....wouldnt the kit come with bigger injectors or fuel pump (i know kits rarely come with these items) if greddy thoguht this was nec? it is not...so the question remains...how much boost you planning on? sure ...in a perfect rich world...yes lets upgrade everything possible...but it is not needed
Old Feb 1, 2006 | 03:15 PM
Dime333's Avatar
Dime333
how much boost could i ask out of a d16y8?
would i have to strengthen any internal parts of the engine?
if so, is this engine worth it or should i swap it, and for what?
i really appreciate your help.
Old Feb 1, 2006 | 03:18 PM
97civicEXVTEC's Avatar
97civicEXVTEC
it all depends on your hp goals. you could most likely handle 9-10lbs of boost with a good tune.
Old Feb 2, 2006 | 11:34 PM
Dime333's Avatar
Dime333
I was reading that all i should ask out of my stock engine is 6psi and to upgrade injectors to which ever fmu system im using. 720cc i think. i dunno.
is this engine worth it i mean, being auto n all?
i was lookn under my sis n laws hood she has a b18c i think im gonna steal it. think she'll notice?
Old Feb 3, 2006 | 10:06 AM
97civicEXVTEC
your car is automatic? then no turboing the car would not be worth it IMO. just swap the d16 for her b18 and call it a day. she won't notice .
