Header information
Old Jan 28, 2006 | 06:58 PM
carrotcake's Avatar
carrotcake
Default Header information
Hi everyone
I am trying to learn things about my car without having the modifications done on my car. Basically I'm here only to learn.
I was wondering what the use of a header is. Does it increase HP? How much does it cost? How easy or hard is it to do the install myself or what would the labor cost? Is it a good investment? What are the effects on others things like fuel efficiency or engine sounds. How often should i get one/ how fast does it rust? Which companies are good, which should I stay away from?
any information imagineable would be deeply appreciated, thanks in advance
p.s. I have a 98 acura EL
Old Jan 29, 2006 | 09:34 PM
carrotcake's Avatar
carrotcake
also wondering if a 98 civic EX header can fit in my car
Old Jan 29, 2006 | 10:23 PM
ReVenGe's Avatar
ReVenGe
welllll.... a header realy doesnt add that much hp. it depends on the engine though. it might make it a tinsie-ist more of a throaty sound.... but im not an expert on it. my header was not your typicle replacement..... cause my stock header had a catalytic converter on it so i gained more than most.
Old Jan 30, 2006 | 06:19 AM
carrotcake's Avatar
carrotcake
what were the main differences that you felt when you got it switched?
Old Jan 30, 2006 | 09:46 AM
ReVenGe's Avatar
ReVenGe
i felt a good power gain on the low end (but thats cause i lost my cat) and ell my car backfires alot because i have no smog device but you wont probably have as dramatic an affect. i would say exhaust would sound a run a little smoother, plus they look cool. headers are used i would say to complete the exhaust if you had a whole system. but dont quote me. get one, there fun and easy to install.
Old Jan 30, 2006 | 11:35 AM
Omniscient's Avatar
Omniscient
warm butter on toast
When buying a header, if you're going to go cheap like DC Sports, you might as well just get an eBay special header because there about 250$ cheaper and will make the same power. Then there's RMF, SMSP, Hytech. Usually custom made 800-1000$, if you're a N/A freak there worth it. There usually custom made to get the most hp out of the specific application.
Old Jan 30, 2006 | 11:39 AM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
aftermarket headers usually increases exhaust flow and increase hp over a factory manifold that usually restricts for emissions purposes.
