Tranny Fluid
Old Jan 26, 2006 | 03:31 PM
rampage918's Avatar
rampage918
Default Tranny Fluid
I have a jdm B16 and was changing the tranny fluid this weekend and wanted to know are there different types of tranny fluid and if so what kind should I get?
Old Jan 26, 2006 | 03:38 PM
97civicEXVTEC's Avatar
97civicEXVTEC
im guessing your car is 5spd so honda MTF only.
Old Jan 26, 2006 | 03:41 PM
fathergoat's Avatar
fathergoat
:3
yes there are different types. is your car auto or manual? I'm not too familiar with what you might need but if you answer that question I'm sure someone can help.
Old Jan 26, 2006 | 03:58 PM
rampage918's Avatar
rampage918
Yeah the car is Manual, Thanks
Old Jan 26, 2006 | 06:11 PM
HcOiNvDiAc's Avatar
HcOiNvDiAc
GOT HONDA?
agreed ... i wouldnt use anything but
Old Jan 26, 2006 | 06:17 PM
Seyless's Avatar
Seyless
My friends with LSD trannys on their b16s use GM syncromesh. They bought it at the dealers for around 35 bucks for three I think. I put it in mine too when I did my swap, though I kept my b18 tranny.
Old Jan 27, 2006 | 07:54 AM
rampage918's Avatar
rampage918
Whats the difference with the GM syncromesh? I do have LSD.
Old Jan 27, 2006 | 09:32 AM
Jafro's Avatar
Jafro
I'm made of meat!
It's synthetic.
Another great alternative to Synchromesh is BG Synchroshift. It's available in a petroleum/synthetic blended BG Synchroshift I, and a full-synthetic BG Synchroshift II.
Synthetic oils reduce friction more than Petroleum oils can. Keep in mind that your synchronizers actually need friction to work properly, so Honda MTF may work better. Using synthetic oils may make shifting MORE difficult despite the reduction in friction. That all depends on the materials used to manufature the synchros in any given transmission and some work better with it than others. Full-synthetic is better in a race car because the transmission usually spends more time at higher RPMs than a daily driver does. I have dual-synchros installed for my 1/2 shift, and my tranny is race-built, so I use BG II. Yes, it's a DSM, but just like a Honda, it's a soft aluminum-cased transmission with forged steel gearsets and bronze shaft bearings.
There are on-line vendors for BG products. Many speed shops like www.machv.com and www.roadraceengineering.com carry them. If you don't like the way your car shifts with synthetic gear oil, it's easy enough to drain it and re-fill it. It's a lot less expensive to use Honda MTF, though. I change my gear oils (tranny, transfer case, rear end) every 5k miles and it runs me about $80. I mix Redline ShockProof and BG II in a 50/50 for the xfer and rear. Thank goodness you don't have to deal with a 3.5qt capacity like I do.
