D Series motor mounts for B series SWAP
Old Jan 22, 2006 | 01:46 PM
Last-of-the-4dr's Avatar
Last-of-the-4dr
Default D Series motor mounts for B series SWAP
Ive been searching around and I herd of someone using the d series motor mounts for there swap only changing the rear motor mount bracket is this true. Can it realy be used?
Old Jan 22, 2006 | 01:58 PM
bambbrose's Avatar
bambbrose
most of them can be used, as they are the same. Which ones I forget
Old Jan 22, 2006 | 02:09 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
depends what year civic
Old Jan 22, 2006 | 02:10 PM
Last-of-the-4dr
Well I have a 1995 civic
Old Jan 22, 2006 | 02:12 PM
teg92's Avatar
teg92
WHAT OK YEAH!
you will need the LS rear mount for sure,the lower tranny mount, and the AC mount, im pretty sure you can use the D series upper mounts
Old Jan 22, 2006 | 02:19 PM
asiandoood's Avatar
asiandoood
thanks to katman for the pix.
File Type: jpg
Old Jan 22, 2006 | 03:26 PM
Hon's Avatar
Hon
all i can tell you about is from D16 to B16. NO different mounts needed. all the d16 mounts can be used for the b16. good luck
Old Jan 22, 2006 | 06:59 PM
Last-of-the-4dr
If i get the hasport motor mount kit do i still got to buy those dam brakets or will i be good to go. And if upgrading from d16 to b16 you dont need different brakets why should it be different to put the b18. because putting the b16 in the integra you dont have to change anything because Ive done it before.
Old Jan 23, 2006 | 04:37 AM
Hon's Avatar
Hon
then there you have it. i think you just answered your own question, lol.
Old Jan 23, 2006 | 09:10 AM
Last-of-the-4dr
Ive just confused the hell out of myself a little bit but I think i can manage. So if i dont get any of these motor mounts or brackets I can just drop the motor in with my d-series crap mounts and brackets
