speedometer not working
Old Jan 20, 2006 | 09:17 PM
ohio_civic's Avatar
ohio_civic
Default speedometer not working
The speedometer in my gf's 94 civic ex auto only works sometimes. I swaped the vss out of my car and it does the same thing. I cleeded the connecter and put contact greese on it. Sometimes the speedo will work, then it just stopes for no reason. Any ideas?
Old Jan 21, 2006 | 05:01 AM
ohio_civic's Avatar
ohio_civic
ttt
Old Jan 21, 2006 | 10:37 AM
gotboost's Avatar
gotboost
was the VSS hard to change your self ???the dealership told me itd be $200, i said f'it i'll do it myself?
Old Jan 21, 2006 | 10:54 AM
ohio_civic's Avatar
ohio_civic
No its 2 10mm bolts. It was on an auto tranny. A manual is probley about the same.
Old Jan 22, 2006 | 11:26 AM
ohio_civic's Avatar
ohio_civic
Well I swaped the cluster out and it works good now. It hasnt screwed up in 2 days.
Old Jan 22, 2006 | 11:33 AM
pvt_awol's Avatar
pvt_awol
yep, I had the same problem, and a cluster swap was what it took in the end. Changed the VSS twice, and still would mess up. (I actually had to change the cluster twice too, but I got a good working one.) Here is why I posted though, my "new" cluster is actually starting to have issues. So, I wonder if the clusters go bad a lot (not likely) or if the car in question has issues that cause the clusters to go bad. Some food for thought.
Old Feb 21, 2006 | 05:27 AM
flyerhky11's Avatar
flyerhky11
When you guys replaced the VSS, did you just get the top part or the entire piece that goes down into the tranny? I replaced only the top part of the VSS and my speedo still doesn't work, and still getting code 17.
Old Feb 21, 2006 | 05:57 AM
Running925's Avatar
Running925
Your Powder Coater
aint' no way in the world that it should cost 200 bux.. it's a 10min job if that. maybe a tad longer if u'r car has the stock intake tube on it & you have to move it out of the way to reach down there!
Old Feb 23, 2006 | 12:55 AM
onesweetcivic's Avatar
onesweetcivic
take out the cluster and check the two grey plugs on eithe side of the cluster via myself a mechanic from honda dealer
Old Apr 4, 2006 | 09:32 AM
flyerhky11's Avatar
flyerhky11
I checked the grey plugs, used a little brillo pad to clean the contacts, and nothing.
