smoke from exhaust
Old Jan 20, 2006 | 06:39 PM
97civicEXVTEC's Avatar
97civicEXVTEC
Default smoke from exhaust
when vtec engages black smoke comes out of my exhaust. nothing extreme, but noticeable. i was just going to switch to a thicker oil to see if it stops. would 10-40w be what im looking for? and will 4 quarts be enough for a d series?
Old Jan 20, 2006 | 11:17 PM
Running925's Avatar
Running925
Your Powder Coater
black smoke is not oil, it's fuel.. it means that your to rich
Old Jan 21, 2006 | 07:43 AM
97civicEXVTEC
so im guessing i need a new o2 sensor then.
Old Jan 21, 2006 | 02:34 PM
Kain420's Avatar
Kain420
Default bump!
bizump!
Old Jan 21, 2006 | 02:48 PM
teg92's Avatar
teg92
WHAT OK YEAH!
maybe you should get something to control your air fuel like a VAFC that way you can rich or lean out your car.
Old Jan 21, 2006 | 03:14 PM
CivicRacr's Avatar
CivicRacr
ive noticed that on a few cars when they floor it and vtec kicks in, its like only a puff of black smoke then it stops. does yours just continues to spit out black smoke in after vtec?
Old Jan 21, 2006 | 07:36 PM
bambbrose's Avatar
bambbrose
a lot vtec activated smoke is white and is caused from the increase in crankcase pressure
Old Jan 22, 2006 | 12:40 AM
REZNEFFIX's Avatar
REZNEFFIX
Mine is the same way. It gives out a white puff when VTEC kicks in and then goes away. I am not worried about it though. I think its normal.
Old Jan 22, 2006 | 12:50 AM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
I was about to say the same thing... My car does that too.
Old Jan 22, 2006 | 01:15 AM
bambbrose's Avatar
bambbrose
keep in mind that although common, this is a sign of minor blowby. Not a big deal however, most B series do it even with 200+ psi in each cylinder
