b18 problems
Old Jan 19, 2006 | 11:32 PM
khristianlee's Avatar
khristianlee
Default b18 problems
ok ok i have some question that i need to clear out ok first i went to some guy i knew he told me that i only need the wiring harness and the ecu then i went to my other friend and he told me that i need the wiring harness the ecu the gas cabel and the axel i want to know if any body put a b18a on hatchback before what are the thing i need for real like all the things i need if i dont get this motor on before the summer start i'm going to be late on my plan...so can somebody please help me i'm in need of help i got a 1,000 limit on the things i need to buy for the motor so please give me a hand... thankx
Old Jan 20, 2006 | 04:32 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
engine (complete)
ecu
transmission
mounts
axles w/ 1/2 shaft
you probably dont need the throttle cable (unless its a 96-00 hatch)
all this has been covered a lot...please search around
Old Jan 20, 2006 | 04:54 PM
khristianlee
what is 1/2 shaft???
Old Jan 20, 2006 | 05:02 PM
teg92's Avatar
teg92
WHAT OK YEAH!
half shaft is part of the driver side axle. Connect to the block with 3 bolts and goes into the tranny. What year hatch is the motor going in?
Old Jan 20, 2006 | 06:24 PM
khristianlee
is a 93 hatchback
Old Jan 20, 2006 | 10:14 PM
riceman643's Avatar
riceman643
dont forget the shift linkage...and the bushings for it.....
Old Jan 21, 2006 | 08:05 PM
khristianlee
oki'm lost i dont know what is that "the shift linkage" or the bushings...help
Old Jan 22, 2006 | 04:11 AM
teg92's Avatar
teg92
WHAT OK YEAH!
if you dont know what any of these parts are then i dont think your ready to do a swap. You have a lot of reshearching to do
Old Jan 22, 2006 | 07:27 PM
khristianlee
well people start out some how ok you was't born knowing honda you learned right...
well
Old Jan 22, 2006 | 07:45 PM
waaBAAH's Avatar
waaBAAH
then buy a book.....not search forums. havent you "learned" people on forums just like to talk?
