civic back door problem
Old Jan 18, 2006 | 09:16 AM
achillis's Avatar
achillis
Default civic back door problem
I have a 92 civic dx sedan w/ auto tranny, manual door and window.
The driver side back door can't open at all. I only find two screws, one on the
door handle and the other on coin pocket. I tried to remove them and found the metal hanger didn't work. How can I fix the problem? I think I need to remove the door panel and connect the metal hanger to the lock? Since the door is closed, how can I remove the panel and reach the hanger? help please.
Old Jan 18, 2006 | 09:58 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
you cant remove the panel until you open the door (removing the handle is the same way)
what happened to keep it shut?
Old Jan 18, 2006 | 10:37 AM
achillis's Avatar
achillis
The door handle doesn't work. I can't open the door from either inside or outside. Now the door is closed. Is there a way to fix it?
Old Jan 19, 2006 | 10:15 AM
achillis's Avatar
achillis
Should I remove the back door first and then remove the door panel? It seems this is the only solution.
Old Jan 19, 2006 | 11:04 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
thats wierd. the inside and outside handles actuate the door latch differently. you sure its actually unlocked?
