iac problems
Old Jan 17, 2006 | 12:16 PM
bigd712's Avatar
bigd712
bigd
Default iac problems
i cant seen to get rid of my idle air controll valve problems i know its common on a ton of hondas im wondering if anyone has a solution to my surging idle im pretty sure its mechanical ive double checked my a/f maps and so on to make sure its not in the tune somewhere ive rebuilt the valve a few times the first time i carefully screwed the plastic plug back into place it worked for a while but now its actin up again even after a coolant flush and the plug is still in place im running a mixture of coolant its 20% glycol about 5 oz per gallon watter wetter and the rest water thanks for any suggestions
Old Jan 17, 2006 | 12:57 PM
VPUPPY's Avatar
VPUPPY
have you check the fast idle thermo valve?
Old Jan 17, 2006 | 02:31 PM
honura's Avatar
honura
Seni
Have you bleed the coolent system?
Old Jan 17, 2006 | 02:52 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Are you sure your ECU is from THAT car? If you have a 5-speed car with an ECU from an automatic, you would have that problem. There's a thread on it. You'd have to remove RP17 and RP18 from the ECU. I did that, and the up and down idle VANISHED! Good luck. In addition to that, I cleaned the heck out of the IACV with carb cleaner. It looked like the bottom screen of a pipe before I cleaned it.
