crank bolt woes
does anyone have any idea how to get the crank bolt out of a 93 civic. I have used a 1/2 drive impact, PB Blaster and heat and no luck. any suggestions would be greatly appreciated. need to get it off so i can change the water pump and idler tensioner.:dunno:
be creative.......lol....they do make a tool that you could buy. looks like a breaker bar with a huge hex shape "key". sometimes crank pulleys have holes in them. (dont know which one but i remeber a crank pully haveing one). stick a srewdriver in there....make sure it is a strong screwdriver bc it probaly will bend with the small holes of the crank pully. last....i repeat last resort.....try .....nevermind...i wont say it........people will call me wacko or something....lol
breaker bar with slide over exension?????um...how do you keep the pulley from spinning? you must have very ,extremly, very good ,awesome compression. lol just go buy the damn tool...i think it is 80 bucks...but then charge your friends for usage.....(everyone will ask for it trust me)
I just put a big strap wrench around the pulley :dunno: it worked fine.
Originally Posted by Däs Schmoo
Or you could put it in 5th gear and have a buddy on the brakes. It does the same thing....but that is assuming you don't have an automatic.
but yes you can do 5th gear and the break and you dont even need a buddy, I have jammed a 2x4 against the break and then slid the seat up to hold it there :goodjob:
http://shoptoolsshoptools.com/shopexd.asp?id=1897
with one of these!!!!
omfg it's awesome... it took me more time to open the package than to get the bolt off. def worth it!!
and i didn't damage anything, or have to try starting the car, or take the starter out.
http://www.sears.com/sr/javasr/produ...table+Wrenches
it's 14.99 and it's a craftsman so lifetime warrenty you could use a strap wrench around the pulley this might work and it's less expensive than that specialized tool you could use it for more that getting the pulley bolt off aswell
