!!!! Over Heat !!!!
Old Jan 4, 2006 | 02:26 PM
busterz's Avatar
busterz
Default !!!! Over Heat !!!!
alrite...2 weeks ago my car over heated...leaking radiator fluid from the radiator.... i refill the radiator with fluid after and it was fine....this is the second time that the car over heated to me....first time was about 6 months ago..same problem...car over heats ...fluid leaks...fill radiator back up...and its fine...but since the last overheat...i can smell radiator fluid...with and without the heat on!! can any one HELP!!!!
Old Jan 4, 2006 | 02:31 PM
Seyless's Avatar
Seyless
Its probably spilled all over. My radiator's seal blew between the plastic and metal at the top and it sprayed way back into the engine bay.
Stupid moutains and long drive back from mexico...
Old Jan 4, 2006 | 07:26 PM
marinecorps's Avatar
marinecorps
Default plug
you could find the hole and plug it up, or just buy a radiator
Old Jan 5, 2006 | 11:47 AM
93hondablk's Avatar
93hondablk
gtr
the same thing happened to me.
you most likely have a broken line some were thats spilling out all the fluid out.
try to see if you can find out after you drive your car for 5 min. if theres any fliud spilling from one of the hoses.If your car smokes thats most likey the problem.(the smoke is caused by the fluid spilling on the enigine because its hot)once you find which line it is just replace it at a machanic.
DO NOT GET RIPPED OFF SOME PEOPLE CHARGE 200
YOU CAN GET IT FOR LESS THAN 50 IF YOU LOOK RIGHT
Old Jan 5, 2006 | 01:39 PM
dpkelly's Avatar
dpkelly
1999 Civic Driver
Get a new rad and new upper and lower rad hoses.
Old Jan 5, 2006 | 07:21 PM
EgRocker's Avatar
EgRocker
brain fart
if you see white smoke the you most likly have a warp head. over heating is a big problem. double check your exhaust. if it is eating you rat water most likly alot of money to fix.
Old Jan 5, 2006 | 08:09 PM
kntcdis's Avatar
kntcdis
do what he said
Old Jan 17, 2006 | 08:22 AM
busterz's Avatar
busterz
and if it is the head (warp) how much would a shop shave it for? and how far should i have it shave...thank you
