Do I Need A Differnt ECU?
Old Jan 3, 2006 | 04:48 PM
90GreenCiViC's Avatar
90GreenCiViC
92 Civic Dx D16
Default Do I Need A Differnt ECU?
ok well my relay didnt have power to every plug when we jumped it with cables..so i went out bought a new one, jumper cabled it everything worked.. pluged it in,,nothing to the fuel pump..ok we decided to check the pump with a big battery fuel pump ran, gas was caming out of filter to when we took out off bolt...ok then i tryed to get a code from jumping the plug the code wouldnt work so im thinking its a bad ecu.....so i can go buy an ecu for 50 bucks for a 92 civic from a
junkyard.. if they let me take it for 30days and it dont work then i can take it back then im gonna buy it because it could not be the problem then id be out 50 bucks...but i want to check with u guys to see what you think..let me so i can see if i have to buyit 2marrrow or not..later,
Old Jan 4, 2006 | 04:44 AM
m735is's Avatar
m735is
Maybe the problem is between the relay and the fuel pump then. Where I have no idea.
Junkyards probably wont refund electrical stuff.
Do you know anyone close by to swap in their ECU?
Old Jan 4, 2006 | 05:21 AM
waaBAAH's Avatar
waaBAAH
dude.......maybe you should finish your other posts. https://www.honda-acura.net/forums/s...d.php?t=218826 and https://www.honda-acura.net/forums/s...d.php?t=218826 why do you keep posting new threads???????? everytime someone responmds...the thread gets "bumped" up back to the top. why is this concept so hard for you?
Old Jan 4, 2006 | 08:31 AM
90GreenCiViC
92 Civic Dx D16
Its Running!!!!!!!!! Needed A New Ecu
