Vx Owners
Old Jan 1, 2006 | 07:56 AM
ILoveJDM.'s Avatar
ILoveJDM.
Default Vx Owners
How does the EGR work? Where, and all you know of this? I believe mine is gone, but I have a bad vacuum leak... HELP
Old Jan 2, 2006 | 03:31 PM
waaBAAH's Avatar
waaBAAH
i take it that you dont know exactly where your vaccuum leak is coming from. what makes you think you have a vaccuum leak? check the sticker under your hood. "might" show you location of egr.(just follow the numbered lines) but otherwise the egr is near the distributor. behind the valve cover. in front of fuel rail. directly in line (pretty close directly in line) with vtec solinoid. spray brake cleaner around where you think you have a vaccuum leak...idle will go up if leak is there.
Old Jan 2, 2006 | 04:37 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
the egr bolts up to the intake manifold towards the left (throttle/passenger) side. If its missing, it should be pretty obvious... it'll look like a bare flange just sitting there on the IM. There will also be an unused wiring connector (or cut wires) somewhere in that viscinity.
Old Jan 2, 2006 | 04:49 PM
ILoveJDM.'s Avatar
ILoveJDM.
In that case, I dont have EGR, it is missing, and I have a vacuum leak, or horrible idle, yet i've sprayed my motor and lines up and down without any result...
Old Jan 2, 2006 | 04:57 PM
white_n_slow
it's my D in a B
do you have a digital camera? The flange would look something like this:
and if it is in fact missing, yes, that would cause a major vacuum leak, as there would essentially be a gaping hole in your intake manifold.
File Type: bmp
Old Jan 2, 2006 | 05:32 PM
waaBAAH's Avatar
waaBAAH
what is your engine code....maybe someone swapped out your motor a long time ago?
Old Jan 2, 2006 | 06:10 PM
ILoveJDM.'s Avatar
ILoveJDM.
Well, it was swapped, but with the D15Z1, stock... Yet it has the Si intake manifold...
Old Jan 2, 2006 | 06:22 PM
white_n_slow
it's my D in a B
well that would explain your lack of egr.
Old Jan 2, 2006 | 06:29 PM
waaBAAH's Avatar
waaBAAH
so now since we figured that out........why do you think you have a vaccuum leak?
Old Jan 3, 2006 | 03:08 PM
ILoveJDM.'s Avatar
ILoveJDM.
It idles up and down, cold and hot, around 1000- 1500 give or take... I followed the write- ups on how to find your bad idle sources... NO Luck.
