Turbo
Old Dec 29, 2005 | 12:09 AM
knightsil-gold's Avatar
knightsil-gold
Default Turbo
I have a 95 civic EX.
Later I will do a GSR swap.
But my questions are, what turbo are yall all using.
I will build the GSR its self to 200HP whp.((i welcome any suggestions on how to do this, I will be sleaving, port and polish the head, bigger TB. So what about bore size, compression, forged pistions, rods,bearings, any and all gaskets, polish and balanced crankshaft, stainless valves(std or oversize), springs and retainers and cams, plus i want the quietest exhaust i can get away with(I hate farts cans) and still have the air flow this setup will need.))
MY GAOL is 250-300, no more then 300 HP, I want the best traction I can
get and still have a beefy setup.
I want the quickest spooling turbo.(what LBS)
I want the a tuff-as-nails motor, so with all this in mind,
would i be closer to 250 or 300??
as far as the turbo, would yall use 2 0r 3 piping, fuel management, elecrical, ignition. and computer.
The car will see no drag strip, except to turn and just for the hell of it, no drag racing.
The car will see alot of freeway(60 hours worth every summer), street and some road course.
Im also looking at Tein Flex coilovers w/ EDFC controller and front and rear sway bars(what size or brand sway bars, I have no clue)
Forgive my poor grammar and spelling, now I know i missed something.
I use to drive a LS so I know the GSR stuff (so-so) but im new at the civic stuff.
please help me out here guys, please no flaming, thats why Ill never go back to honda-teck.
You guys kick a$$
La,
shane C.
Old Dec 29, 2005 | 12:54 AM
knightsil-gold
oops, thats " Tune at the drag strip"
Old Dec 29, 2005 | 11:01 AM
b16ahybrid's Avatar
b16ahybrid
Whats your budget?
The motor can easily handle 300whp so your 250 -300 hp goal is easy. Since you did mention you want a tough motor, I would recomend a set of rods and pistons (eagle rods, and j/e, wiseco,etc for pistons), sleeves arn't necessary because you can easily make 450whp on stock sleeves. I don't know a whole lot about headwork so I'll leave that to someone else to answer.
Tuning...look into hondata for tuning....
A lot of the stuff that you inquiring about is stuff that you should research on your own...
Why are you planning to build the motor to 200hp N/A then going woth boost?
Those are two different worlds of power production, some concepts are simular and a lot are different.
Old Dec 29, 2005 | 11:11 AM
97civicEXVTEC's Avatar
97civicEXVTEC
you could get your 250-300whp goal just from aftermarket rods.
Old Dec 29, 2005 | 11:12 AM
Omniscient's Avatar
Omniscient
warm butter on toast
I'm not to sure you can build the motor for 200whp then turbo it because you would want to lower the compression to handle more boost, or if anything get a stronger same compression/bore piston. To save my self time, just read what the guy above me said.
But you might aswell get aftermarket rod bolts and head studs as well, just for added insurance.
Old Dec 29, 2005 | 11:58 AM
b16ahybrid's Avatar
b16ahybrid
You can get that on stock rods and pistons.........
