Troubleshooting Accessory Plug 99 Civic
Old Dec 27, 2005 | 09:56 PM
mll37's Avatar
mll37
Default Troubleshooting Accessory Plug 99 Civic
Can anyone offer any advice on how to get my accessory plug working again? Already took out the center console to check the connection in the dash. Also, after looking under the hood found the same color wires that run from the back of the accessory plug. Is it safe to assume that these are the same wires or could the wires be coming from somewhere else? Thanks in advance for any help.
Old Dec 27, 2005 | 10:49 PM
bambbrose's Avatar
bambbrose
whats it doing?? more information please
Old Dec 28, 2005 | 10:50 PM
mll37's Avatar
mll37
It's just not working. Tried plugging my radar detector and several other things into it. None work.
Old Dec 29, 2005 | 03:23 AM
bambbrose's Avatar
bambbrose
ah hyou mean the cig lighter.. ok.
Do you have a voltmeter? or at least a test light?
If so check the 2 wires heading into it for 12v power. One of them should have it with the ignition in the on position.
Check your fuses, you have a 10amp fuse specifically for the plug.
I doubt the wires under the hood are the same thing, but its possible.
I think they just run off of the fuse box 12v however. So check your wires right after the console and get back to us
Old Dec 30, 2005 | 06:43 AM
monicle's Avatar
monicle
Repo.Jackmoves.Com
you have the car turned on right? i knew someone who thought it wasnt working but was trying to test it while the car was turned off.
