ok this is probably one of the simplest mods to do by your self, alle u need is a 19mm, 17mm, 10 mm and a jack, if you can get the strut out then all you have to do is put your foot on the actual spring, and loosen it up from the very top and the spring will fly off and then you just reverse the process. If you need more detailed info on this, email me joshcushing19@hotmail.com
