did a swap and car won't start
Old Dec 19, 2005 | 03:28 PM
mycivic1993's Avatar
mycivic1993
Default did a swap and car won't start
I just swapped a d15vtec into a 93 dx. I used the the same stock harness and didn't hook up the vtec, well not til spring. When I finally cranked it over the engine turned over for a few seconds then saw some sparks flying out by the starter. Then tried starting it again and getting nothing. Is it just the starter? forgot to mention I had the battery hooked up to a charger and in start mode. did it have too much voltage? Need some info please, been dreamin' bout driven her again. Thanks
Old Dec 19, 2005 | 04:58 PM
teg92's Avatar
teg92
WHAT OK YEAH!
take your starter off and bring it to get checked. Do you hear a clicking sound when you try to start the car?
Old Dec 19, 2005 | 05:00 PM
mycivic1993
no, noise at all. all the fuses look good. Don't know what happened.
Old Dec 19, 2005 | 05:02 PM
teg92's Avatar
teg92
WHAT OK YEAH!
You check all the grounds? Check the battery voltage
Old Dec 19, 2005 | 08:53 PM
Running925's Avatar
Running925
Your Powder Coater
the positive wire from your starter either slipped off the pring or your grounding wire is touching the positive, look at the angle it's connected & make sure the positive isn't grounding against the starter casing.
i doubt you fried the starter, they can take quite a bit of electrical abuse (from past experience)
Old Dec 20, 2005 | 04:43 PM
mycivic1993
I just took my starter to autozone and it passed the test. isnt the starter grounded by being bolted to the tranny?
Old Dec 20, 2005 | 06:11 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
there is also the little black spade connector. but if the positive cable is grounding out or close to it, it will make a nice light show when you try to start it.
