What's the possibility of hitting a mid 15 in an EX?
Old Sep 13, 2002 | 12:28 PM
likaciv's Avatar
likaciv
Pretty Much its a Civic
I ran a 15.9 at 82mph with I/h/e and a centerforce clutch. With a good launch and some slick shifting you should be there. Im planning or hoping i should say for the lower half of the 15 range now
Old Sep 13, 2002 | 01:20 PM
pinoydon2003's Avatar
pinoydon2003
ok, drag newb right here..
wut exactly do u mean by a "good launch"?
Old Sep 13, 2002 | 01:22 PM
oc_civic's Avatar
oc_civic
mcc racing
nice solid high rpm launch with minimal tire spin.... just good solid launch with good hooking
Old Sep 13, 2002 | 05:58 PM
Mike99's Avatar
Mike99
U.S. CoastGuard
BTW to show how the conditions of the track weren't too good. My mother's car is a 99GTP and it had maybe an extra 50Lbs of junk at most and it ran a 15.4 @88.6mph with a 2.3 60foot. I didn't want to burn out for traction because it was her car but is a somewhat decent 60foot.
Old Sep 13, 2002 | 09:57 PM
D16ROCKET's Avatar
D16ROCKET
I AM GLAD THAT I SAW THIS POST. WHAT THE HELL IS THE DEAL WITH MY CAR. I HAVE A 96 EX WITH A 99 EX MOTOR WITH LESS THAN 40K MILES WITH AN AKIMOTO INTAKE, DC SPORTS 4-2-1 CERAMIC HEADER, AND TANABE RACING MEDALLION CAT BACK, AND TONIGHT I RAN A 17.0 TO 17.2 1320 AT 81-82 MPH ON A SET OF SLICKED OUT KUMHO'S SET AT 25 PSI. I KNOW A STOCK CIVIC IS SUPPOSED TO RUN ABOUT A 16.8. I HAVE AN AFPR SET TO ABOUT 32 PSI AT IDLE. AM I RUNNING TOO RICH AND IS THAT MAKING THAT MUCH OF A DIFFERENCE? ANY HELP IS APPRECIATED. OH, 60FT TIMES WERE HIGH 2.4s. I WAS EMBARRASED OUT THERE, BUT THEN AGAIN, IF I GOT THEM ON THE AUTOCROSS COURSE, I WOULD HAVE EATEN THEM UP, SO IT'S ALL GOOD IN THE END.
Old Sep 14, 2002 | 05:40 AM
crucial Si's Avatar
crucial Si
Banned
why u using caps...cant read it...ahhh
wow a 17.0 is slow. you ran a pretty good 60' but after that you just die out....
Old Sep 14, 2002 | 06:45 AM
oc_civic's Avatar
oc_civic
mcc racing
tell me the fuel psi at idle with the vacum line removed mine is 40 with the line removed but i also run a bottle, SO...if it is 32 with the line OFF then that psi is fine... if it is not fill me in on what it is with the line removed
Old Sep 14, 2002 | 08:53 AM
D16ROCKET's Avatar
D16ROCKET
Sorry about the caps. I made an error typing in the psi, it is 38 at idle and 45 at w.o.t. (vacuum line removed). Let me know. Also isn't w.o.t. supposed to be 10 psi higher than idle? Could my fuel pump be going out? I have a pump from a 00 Si on standy if my pump is bad though.
Old Sep 14, 2002 | 09:26 AM
oc_civic's Avatar
oc_civic
mcc racing
45 is WAY high... you are BOGGING at wot just liek i was all motor.. i say honestly for your application that 38 - 40 with the line removed is MORE than enough fuel...
Old Sep 14, 2002 | 02:01 PM
likaciv's Avatar
likaciv
I was under the assumption that a higher psi just prevents the injectors from going dry, The injectors will only pump in what they are rated to.
