Faulty fuel filter?
Old Dec 10, 2005 | 12:55 PM
schuylkill's Avatar
schuylkill
Default Faulty fuel filter?
I tuned up my Civic cx and ever since unless I'm drugged the car is getting way worse fuel mileage. I replaced the fuel filter, plugs and distributor cap (screw is stripped on rotor, I'm working on it.) I commute 160 miles per day so I really notice the difference in fuel consumption. Could the problem be a bad filter? The car seems to be running fine, doesn't hesitate or anything and no smell of fuel. Any suggestions? I'm thinking I should try another filter? Thanks.
Old Dec 10, 2005 | 09:18 PM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
I doubt a new filter is the problem, especially if the car doesn't hesitate and stuff. Did you put the correct NGK plugs in the car?
Old Dec 11, 2005 | 11:42 AM
1995Civic's Avatar
1995Civic
I hate ricers
You could have possibly gapped the plugs incorrectly, and you could also have a O2 sensor. I would also suggest finishing up the tune-up w/ wires, rotor, coil, and O2 and see how you're doing then.
