Trailing arm help
Old Dec 8, 2005 | 06:35 PM
Chaser86's Avatar
Chaser86
Default Trailing arm help
hey, ive got a 1.6 el and my trailing arm bushings are shot, so i took the bolts out but it still wont come out is there a trick 2 it or somthing? any tips?
Old Dec 8, 2005 | 09:11 PM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
you have to remove the entire arm from the car, meaning, undo the brakes, undo the control arms
When the whole arm is off, replace the bushing (you will need a hammer or a press, either is fine
Old Dec 9, 2005 | 12:54 AM
Kai's Avatar
Kai
Rotorphile.
You don't have to completely remove the trailing arm from the car. The bushing will hammer out.
Old Dec 9, 2005 | 04:21 AM
PDiggityDogg
Id love to see a new one being put in while still on the car...
Old Dec 9, 2005 | 04:31 AM
Civic2Scooby's Avatar
Civic2Scooby
it can be done.
Old Dec 9, 2005 | 06:55 AM
PDiggityDogg
Real bushings or those urethane pieces of trash?
Old Dec 9, 2005 | 07:13 AM
Civic2Scooby
real, and the ES bushings are far from peices of shit.
Old Dec 9, 2005 | 08:16 AM
PDiggityDogg
ok, they just cause binding, improper movement of the arm, and the pin can slide out under load. Yeah, great design
Old Dec 9, 2005 | 03:51 PM
Kai's Avatar
Kai
Rotorphile.
If you can find a Honda dealer that will let you into the shop, you'll see it.
Old Dec 11, 2005 | 09:31 PM
georgelb's Avatar
georgelb
Suspension ++
http://honda-tech.com/zerothread?id=1456600
