fuses
there are three thing that you need to make your radio work.
1 constant
2 accessory
3 ground
constant fuses will ususally be under the hood about a 10 or 15 amp fuse. another why to check to see if this works is if your dome light works.
usually
accessory fuses will be in the kick panel and is a 10 amp fuse.
ground just need to touch to metal of your car
if all else fails pull out each fuse one at a time and check them all. or buy a multimeter and pull out your radio and check your wires
1 constant
2 accessory
3 ground
usually
