Looks Like I'm Finally Gonna Boost...
Old Dec 1, 2005 | 09:31 PM
delsol161's Avatar
delsol161
Default Looks Like I'm Finally Gonna Boost...
yup. tonight 2gr84u suggested checking out www.homemadeturbo.com. there, i found a guy selling parts of a turbo kit. as i talked to him, i decided... it's mine $430 shipped is going to get me the following...
"-manifold
-t3 turbo
-flanges
-lines, block fitting
-fmu
-missing link
-downpipe
-6psi wastegate
-2.25" steel pipe with 1st gen dsm bov (blue)"
i know it isn't complete. but two things hooked me... its cheap, and better than the turbo setup i DON'T already have. lol, so hopefully within the next couple months, i'll get it all put together and have it runnin. hoping with a few other mods to get near / past 200 hp. need to get some gauges, uberdata, some piping, clutch & peolly some other lil odds & ends.
Old Dec 2, 2005 | 12:19 PM
delsol161's Avatar
delsol161
not sure exactly what all i need. i know i need a timer, but this is my first turbo build so i need some input. thanks guys
Old Dec 2, 2005 | 12:24 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You don't NEED a turbo timer, but it is nice. I really think you should look first at some better fuel management than an FMU and missing link.
If you don't yet have exhaust, you will want to look at something a bit larger too.
Your list looks good, but you will also need some larger injectors if you want to get serious with the fuel management.
Old Dec 2, 2005 | 12:32 PM
delsol161's Avatar
delsol161
ok, i figured instead of the turbo timer, i could juss let the car sit for a few minutes brfore i shtu it down. i've got all my exhaust replaced, except the stock pipes. i figured i might go a half inch bigger to relief the extra backpressure.
as far as the FMU and missing link.. .what would you suggest?
Old Dec 2, 2005 | 12:41 PM
Running925's Avatar
Running925
Your Powder Coater
Bigger injectors & chipped & tuned ECU
Old Dec 2, 2005 | 12:45 PM
extensioncordy's Avatar
extensioncordy
EG6
ok, i've got all my exhaust replaced, except the stock pipes. i figured i might go a half inch bigger to relief the extra backpressure.
then what do you have replaced? if the stock pipe isnt replaced? im confused please re-word that
Old Dec 2, 2005 | 12:47 PM
delsol161's Avatar
delsol161
sorry, i mean the cat, and axel back. from cat to axel bck, the stock pipes are there. i said it wrong.
450 injectors would be plenty right? 2gr84u said he has me covered on getting my ecu utaken car of
Old Dec 2, 2005 | 01:44 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
stuff you need or should highly consider:
450cc injectors
walbro fuel pump (190 is sufficient)
u need a fitting welded into your oil pan
intercooler
BOV
couplers
boost guage
ditch the missing link and FMU, pick up or chip your ecu for uberdata.
Old Dec 2, 2005 | 02:12 PM
delsol161's Avatar
delsol161
450cc injectors
intercooler
BOV
couplers
boost guage
yeah, the injectors i was sure of. where can i find the fuel pump? the fitting is easy, it'd prolyl take me a few minutes to weld it on. FMIC is nex ton the list. BOV comes w/ the kit. couplers should be fairly painless to come across.. and stupid me juss sold a boost gauge 2 weeks ago. need one now.
i have an AEM fuel rail i got last year. is it worth putting on (w/ a FP regulator)? or wil lthe fuel pump be enough?
Old Dec 2, 2005 | 02:40 PM
Provocateur
On permanent hiatus
The AEM rail is pointless. It wouldn't be worth your time to put it on, unless you change the injectors out.
