Help With SI Engine Please Reply FAST
Old Dec 1, 2005 | 01:15 PM
90GreenCiViC's Avatar
90GreenCiViC
92 Civic Dx D16
Default Help With SI Engine Please Reply FAST
ok theres this car i want to buy its a 92 honda civic with a 91 si motor out of a hatchback.and it needs a 1.6 computer wiring harness.they said it wasnt firing up right or somthing so thats what they think it is.i dont no what that is or how much they cost so if you could give me some information it would help me out alot..thank you
Old Dec 1, 2005 | 02:30 PM
CaliDELSOL93si's Avatar
CaliDELSOL93si
if you don't know what a wiring harness is and don't know how much they cost, DON'T BUY THE CAR. You are gonna get f***ed. Don't buy the car, trust me.
Old Dec 1, 2005 | 04:43 PM
brusk's Avatar
brusk
you shouldn't need a new harness for anything. Most of the harnesses are basically the same. The only time it's difficult to modify a harness is if your going from dual point fuel injection to multi point. As for needing the 1.6 ECU you don't have to have it much it's preferred. 91 was before honda used OBD1 on the civics so the ECU wouldn't be compatible with the wiring anyway. Depending on what model of civic it is will depend on the level of difficulty to fix the problems. If everything is such a hurry or important you should post pics and give some more details.
Old Dec 1, 2005 | 06:48 PM
Omniscient's Avatar
Omniscient
warm butter on toast
It should still fire up even if a sensor or two isn't working. Then if it doesn't fire up it should throw atleast 1 CEL for something. Honda's can fire up with a slew of sensors not hooked up.
Old Dec 1, 2005 | 09:35 PM
Wharbone's Avatar
Wharbone
I'd get a different car. Having an older engine than your car is illegal. Could lead to problems in the future.
Old Dec 2, 2005 | 07:10 AM
Civic2Scooby's Avatar
Civic2Scooby
you already posted this question in this forum like a day ago...stop multi-posting the same question.
Old Dec 2, 2005 | 07:29 AM
90GreenCiViC
92 Civic Dx D16
id like to close this post
Old Dec 2, 2005 | 08:55 PM
Redcivic's Avatar
Redcivic
One of the original OG's
91' in 92' civic = bad idea. How much HP is a 91 si motor? D16A? right?
Old Dec 5, 2005 | 04:34 PM
90GreenCiViC
92 Civic Dx D16
motor is 1.6 ..D16A6
Old Dec 7, 2005 | 11:54 AM
darkskyracing's Avatar
darkskyracing
Simple don't be cheap and get something to work with even if it's basic like my 98 ex
