need some engine advice...
Old Nov 30, 2005 | 07:39 PM
jdm-power's Avatar
jdm-power
Default need some engine advice...
got a 93 civic whoz head is preety messed up....
what all choices do i have upon the change of head?
havent worked on a civic so just wann make sure and get some knowledge before i start doing any kinda work...
is it better to change the head or just do the whole engine?
any 411 regrding this would be greatful
thankxx
Old Nov 30, 2005 | 07:44 PM
Omniscient's Avatar
Omniscient
warm butter on toast
What's the car for? Do you mind losing some reliability? How much money do you have? What are your goals? What model civic is it?
Old Nov 30, 2005 | 07:54 PM
jdm-power's Avatar
jdm-power
the main purpose of the car would be to run, its my bros car and it has been sittin in the garage since the last 8 months. just sold my prelude and i need a car to kill the winter. budget to spend on it is around 700.
wat the car does is it starts up and its alryte, but as soon as it gets warm smoke starts to come, vibrates like crazy and eventually shuts off.
1st and 2nd spark plug has oil in it.
one guy i know told me u have to change the head gasket, but im really not sure what al to doo
Old Nov 30, 2005 | 11:54 PM
CaliDELSOL93si's Avatar
CaliDELSOL93si
hmmm....headgasket is definately gone since you have oil in the spark plug holes and you are blowing smoke. What color smoke ? More white or more black ? I suggest doing a full tune up and going from there. Change wires, plugs, cap & rotor, hosing, etc....
Old Dec 1, 2005 | 07:18 PM
jdm-power's Avatar
jdm-power
pure white smoke around the head and block area....underneath the exhaust manifold head shield...
i also think its the headgasket so would be changing it as soon as i get it...
opened everything and cleaned em out..
Old Dec 3, 2005 | 08:27 AM
jkjk's Avatar
jkjk
You would need the head machined. Every aluminum head I've taken off was warped just slightly. I think that happens from heat and age, and may be the cause of your head gasket problem. While the head is off consider having the valves seated and having the rubber valve seals replaced.
Attaching the intake manifold to the head and torquing it is a major pain in the ass.
Old Dec 3, 2005 | 09:50 AM
CaliDELSOL93si
yeah, the head machined along with maybe getting the block resurfaced, with a new headgasket and you should be good to go.
