unchanged tranny fluid?
what kind of things would you start to notice if you havent changed your tranny fluid in a long time? not that im in that situation or anything......
Originally Posted by b20hatchy
IS it true that you should only replace trans fluid with honda factory or it will grind?
for the older D series SOHC's, the Honda manual recommends just using 10-30 motor oil. For the B series...they recommend using Honda MTF.
I am assuming the newer D and K series now recommend Honda ATF or MTF.
VX Hatch with 431,500!
Two things can happen to the fluid. It can smell slightly burned. Or it can be dirty. I assume it's dirty and doesn't smell.
Just change it now. I don't have a manual in front of me but I assume there is a filter to change in the transmission pan. I'd change it if there is.
The big thing that happens is that not changing the fluid puts a little more wear on the parts. I just gave my brother a 1992 Accord with 172k on it. I got it from a friend at 150k. I never changed the fluid and I don't think he did either. It shifts fine.
