95 civic idling up and down?
ok, i got the idling to stop . I use a throttle body cleaner and i adjust the IACV (Idle Air Control Valve), It would do it when i start the car and when i was driving,it was idling all the time,this idling was driving me :crazyr: crazy,i just hated it when i was :driving: driving.But thanks to all,:goodjob: i found the problem.:hi5: I just hope it doen't comeback.
One of the original OG's
This can also be caused by a bad throttle body gasket. Just so you guys know it's a fairly common problem when I do swaps with junk yard engines that have been exposed to the elements.
Things you should do:
Test your FITV. To do this:
1. Remove your intake pipe from your throttle body.
2. Start your car.
3. Cover the small hole in your throttle body. It should have suction. If not, replace your FITV.
4. Let your car warm up to opperating temp. Let your fan kick on at least two times.
5. Cover the small hole in your throttle body again. Now it should not have any suction. If it does, replace your FITV. This part is about $50
Check for vacuum leaks. This picture shows the vacuum line you should check. Check by spraying them with soapy water, and look for bubbles. Also spray the throttle body to see if the gasket is leaking.
Clean your IACV (same thing as EACV, IAC) with carb or brake cleaner. You may also need to replace this. I'm not quite sure how to check it. One way I think you can check it is disconnect the 2P connector to it while the car is idleing. The RPM's should drop quite a bit. It is a semi-expensive part (about $130).
Replace your PCV valve. It's only a couple of bucks from your local auto parts store.
2. Start your car.
in most cases, you wont need to replace the FITV...you just need to screw the plunger that backed out back into place.
Today i took the intake pipe out of the throttle body and it did have suction,i left the car on for about 10 minutes and then again i cover the small hole inside the throttle body and it had suction but as soon as i cover it with my finger the engine stop idling,so i got some pieces of masking tape to cover the hole,i dont know if this is gonna cause any problems,but the car is not idling.I think i have to replace the exaust manifold gasket,i hear a loud noise when i accelate,maybe this is causing the problem.
Which hole?
It sounds like your FITV that backed out. Do a search for my post on how to resolve that. I highly suggest you dont use masking tape. It will get sucked into your engine.
