clutch pedal prob...
my clutch pedal has about a inch of travel when u tap on it... like free space before it actually disengages the clutch...its all loose in that 1in any idea what to do?
check your fluids
check the MC
tighten the screws behind the pedal.
check the MC
all clutch pedals have that 1-inch of travel. It is called "free play" it is adjustable too, so if you want to get rid of it, I guess you can. In the chilton's manual, it says that the free play should be 0.6-0.8 inches.
So, I would just leave it the way it is. That would be my advice. Probably there for a reason.
Originally posted by SpeedRacerEX-R
I don't think it's a problem now that it's broken.
i thought the prob would still prosist being that im not changn my clutch pedal
if u wanna adjust it, where the pedal engages into the master cylinder, there is a nut u can screw. the more u screw it, the pedal will go in further eliminatin ur play. i did this to my friends accord when i swap his auto tranny out and threw in a h22 5 spd.
late
late
