Correct Transmission??
Well...I purchased my Si a few months ago and had some engine work done. When I purchased it the RPM rage seemed a bit to high so I had a stock tranny put it and it still seems off. When I am going 100 in 5th gear I am at 5 1/2 RPM's. Thats seems high to me. I talked with my friend and he has my same engine but he said he can go 120 and be at 5 1/2 rpm's. Is there a different transmission I am supposed to have or is it something special. Let me know because I am lost at this situation! O_o
Yeah. I am not sure what Tranny I have nor what he has either. I just remember when I test drove an acura integra before I got my SI...it had the same engine as my car but the range between shifts was a lot more. I am on the highway alot so it is at 4 grand or so so my car gulps the gas. I wasn't sure if there was a diff tranny I could have so it wasn't running so high and I would save gas....but what you are saying is If I get that tranny I would be slow?? Can't I just downshift into 3rd versus 4th and still have the high rpms to get up and go or will I lose the go when I shift up a gear and it drops down low?? Little lost here. Any help would be appreciated.
Whats the difference between s4 or s4c??
Putting in an LS 5th gear...will that just make it drop down a little more when I go into 5th so I have more of a range to go? ALso will that slow down my car or is an LS 5th gear better or something? O_o
