Firing Orders??
Old Nov 3, 2005 | 07:03 PM
Wigin24's Avatar
Wigin24
B16/b17
Default Firing Orders??
Hey guys im in need of your expertise. I have a 96 EJ8 with a B17 block(CTR Pistions rehonned etc...) With at 00 SI (PR3) Head. Ok Ive ordered all the parts from all over sent it to a place in Missorri For assm. Came Back and now its my job to get it running. The Ecu is allready been chipped and Tunned by Mugen so no knock sensor or secondary O2 sensor to worry about. Im using a TD-68U GSR Distb. The only prob is im not sure which way it goes on? Does the line on the distrib face the Radiator.(of course when set to TDC) And What firing order do i use.
14 43
23 or 12
Everything else seems good to go... Ill check on the timming in a little just want to make sure distributor is correct. Thanks for the help.
Old Nov 3, 2005 | 09:42 PM
Kai's Avatar
Kai
Rotorphile.
Honda four cylinder engines use a 1-3-4-2 firing order.
