Circle Racing 15x7 aluminum- what Backspace?
Old Nov 2, 2005 | 12:31 PM
sleepin's Avatar
sleepin
Default Circle Racing 15x7 aluminum- what Backspace?
http://www.circleracing.com/Me...de=rr
EG8 with teg brakes front and rear
205 tires.
Want them to be flush with fender, but a bit of pop out is fine.
I just need backspace in in inches to order them up.
I did search and came across 5", but that was for 13x9 and wasnt sure if it would be the same for 15X7.
Thanks.
Old Nov 2, 2005 | 01:48 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
You want a 40-45mm offset. You don't want the wheel/tire sticking out. 1) it looks stupid, 2) you will run into rubbing issues, 3) you will be considered a low rider
Autocross Help Page
Old Nov 2, 2005 | 01:58 PM
sleepin's Avatar
sleepin
After a bit of looking I came up with 42. How would that look? Would it be flush with fender?
Old Nov 2, 2005 | 05:45 PM
CivicSiRacer
The difference between 40-45mm is only 4cm=1.25". Barely even noticeable. And as I said you don't want it "FLUSH" with the fender because if you drop it it will rub. But it will tuck a little bit compared to a 35mm offset.
Autocross Help Page
