Camber Kit
Old Oct 29, 2005 | 06:55 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Default Camber Kit
Which camber kit would be the best buy? I found out I need a kit, now that I noticed I got some series wear on the inside of both my front tires. Was deciding between the Ingalls, Skunk2, and the Omnipower set. Which do yall recommend?
Old Oct 29, 2005 | 07:01 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i got my omni kit for 150 from inlinefour.com. after you get the camber kit installed it would be wise to get an alignment.
Old Oct 29, 2005 | 07:16 AM
Wharbone's Avatar
Wharbone
You may just need an alignment. Toe will kill your tires much faster than camber.
Do you rub at all with your current set-up? I seem to remember your car slightly tucking the wheels. If you adjust the camber, you may rub more.
I use the omni front kit. It is really easy to adjust. All you have to do is jack the front of your car car and use a 7mm allen wrench. I didn't even have to take off my wheels.
I used a level to estimate my camber correction before I took it to have the alignment done (next day). One side was perfectly at 0 and the other was almost perfect. My toe was way off though. Toe was the cause of the inside of my tires getting eaten up.
Old Oct 29, 2005 | 02:39 PM
1995Civic's Avatar
1995Civic
I hate ricers
Omni for sure.
Like Wharbone said, toe will kill tires faster than camber.
