skunk2 coilover o-rings???
Old Oct 28, 2005 | 12:38 PM
DatHatch219's Avatar
DatHatch219
Default skunk2 coilover o-rings???
what up
did u guys put on the o-rings that came with the skunk2 coilovers???
also did u cut ur bump stops?
thanks
Old Oct 28, 2005 | 01:35 PM
syclone's Avatar
syclone
not sure how you're going to keep the sleeve in place if you don't.. cutting the bumpstop is dependent on how much you lower your car.
Old Oct 28, 2005 | 06:50 PM
DatHatch219
i'm planing on lowering around 2 1/2 front n rear??? should i cut the bump stops?
Old Oct 28, 2005 | 07:48 PM
DatHatch219
up...
Old Oct 28, 2005 | 10:52 PM
syclone's Avatar
syclone
yes.. cut it in half
Old Oct 29, 2005 | 07:11 AM
DatHatch219
thanks
Old Oct 29, 2005 | 04:07 PM
swaggs21's Avatar
swaggs21
yes, you have to use the O-rings that came with it in order to keep the sleeves from beating the hell out of your stuts. You want to choose the one that it is just a little loose with, then wrap duct tape over the rings when you get them where you want to make sure they dont move.
Let me know if you need any more help.
