Heater not working....
Old Oct 23, 2005 | 11:47 PM
nvd13ymost's Avatar
nvd13ymost
Default Heater not working....
Can anybody help me figure out whats going on with my heater. I checked for fuses and they all fine, and im still not getting any heat inside my car...Help!!
Old Oct 23, 2005 | 11:52 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Does it turn on? Are you just getting cold air? Are you getting any air at all?
Old Oct 23, 2005 | 11:57 PM
nvd13ymost's Avatar
nvd13ymost
it turns on, but i get cold air....
Old Oct 24, 2005 | 07:29 AM
nvd13ymost's Avatar
nvd13ymost
anybody else...
Old Oct 24, 2005 | 08:31 AM
reztoration's Avatar
reztoration
just cold air? i assume the blower is working. have you checked or changed the antifreeze? my last sugestion-heater core.
Old Oct 24, 2005 | 10:11 AM
teg92's Avatar
teg92
WHAT OK YEAH!
check your thromstat and also check if you have enough coolant
Old Oct 24, 2005 | 12:05 PM
Omniscient's Avatar
Omniscient
Also feel your heater hose. Squeeze it to test the flow and warmth.
Old Oct 24, 2005 | 03:45 PM
Ctrld-Kaos's Avatar
Ctrld-Kaos
i need a wrench wench
I would check the heater core... depending on the age of your ride and the way its driven, you could have cracked it. atleast your ride isnt spitting boiling hot fluid out of your floor vents.. i still have scars..
Old Oct 24, 2005 | 11:24 PM
nvd13ymost's Avatar
nvd13ymost
thanks guys, it everything seems that its my heater coil. Does anybody know how hard it is to change it? is it time consuming?
Old Oct 28, 2005 | 12:28 AM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
What? How about some proof reading and some punctuation so we know what you're trying to say.... Before you do the heater core swap (huge job, expensive, and probably not your problem).... Did you or didn't you check your coolant level? Does the interior fan run? Does your temp needle go to the normal level or stay low (thermostat stuck open) or is the needle high and your car is over heating (low coolant and posible leak). Is there coolant getting in the car (floor board)? Did you check the valve that controls the flow of hot water into the heater core. It is located at the fire wall on my '92 on the heater hoses. Have a friend watch it while you turn the lever inside from hot to cold. Does it move? is it not conected or broken?
