Auto To Manual Convertion!!
Old Oct 17, 2005 | 07:27 PM
lilriceburner's Avatar
lilriceburner
>94' Civic Si Coupe
Default Auto To Manual Convertion!!
I have a 1994 Civic EX coupe... can someone make me a list of the things i need for a automatic to manual conversion...including total cost and labor time...and if anyone knows a local shops that will do it for cheaps or something. i would apperciate it
Old Oct 17, 2005 | 07:32 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
dont know how much it would cost because i normally do things myself.
you need:
manual tranny
clutch master cylinder and hardline running from it to the slave cylinder on the tranny
manual ECU
manual pedals
shifter and linkage
thats just off the top of my head, can someone else list more if there is any?
Old Oct 17, 2005 | 11:59 PM
Kestrel's Avatar
Kestrel
Push to shock!
Wait, didn't you just say you drove a manual in your other thread?
Old Oct 18, 2005 | 02:52 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I would say it's not practical. And that you'd be better off with a car that was made as a manual. It would really be all the little bits and pieces that would kill you and not the transaxle itself.
Old Oct 18, 2005 | 04:25 AM
lilriceburner
>94' Civic Si Coupe
I have 2 honda civics...i have an SI HB 93 (raceing) and i have a 94 ex coupe (Daily driver)
Old Oct 18, 2005 | 06:18 AM
boriblanco's Avatar
boriblanco
go to a junk yard and take out the clutch pedal, slave cylinder, u need a tranny with linkage ,and ecu. the cost might depend where you go to get it done its really not that hard to do all the cut outs are there so its just simply putting everything in place..
Old Oct 18, 2005 | 07:18 AM
Running925's Avatar
Running925
Your Powder Coater
i think thats a totaly stupid comment & it could be done for well under 500 bucks
Old Oct 18, 2005 | 07:22 AM
Running925's Avatar
Running925
Your Powder Coater
1. Manual Tranny (slave cylinder should be attached still.. if not, u need it)
2. Clutch & Flywheel
3. Auto to manual mount (or re-locate mount on frame rail)
4. shift linkage & shifter
5. pedal assemblys
6. Master cylinder
7. go purchase hard line from parts store & $5 bender
8. Tranny fluid
9. trade the junk yard ECU's
good luck
Old Oct 18, 2005 | 05:04 PM
hybridhondahatch's Avatar
hybridhondahatch
for that added pep
take it from me ive done it a couple times now, not that bad really a good weekend project, and is alot eaiser if you just suck it up and take the whole motor out of the car.
Here is a complete parts list
-tranny
-clutch
-pressure plate w/ bolts
-flywheel w/ bolts
-clutch master cylinder, line and slave cylinder
-5spd pedal assemblys (yes both the clutch pedal wont clear an automatic -brake pedal)
-shift linkage
-rear mount
-ECU
-top tranny mount (see below)
-5spd cluster (not really needed but makes it look cleaner)
the top tranny mount can be taken care of a few ways, either cut and weld (too much work IMO) or you can purchase a mount specifically for this conversion, HCP makes it and it can be found at the link below, it is the last mount pictured. newman sold me and my buddy the for $155 from JDMshit (he runs the site)
http://www.jdmshit.com/hcp/index.html
a few negatives about this swap:
-holes in your floorpan unless you have someone who can weld
-you also wont have reverse lights although i have heard that this can be resolved by wiring the yellow and green wires (by the stock shifter) to the reverse signal wires on the tranny (the wires by where the slave cylinder mounts).
-the little white plastic slider peice on the automatic shifter (you'll know it when you see it) must be locked in the park position some how (mine is epoxied)
-you will be able to start the car w/o pressing in the clutch so make sure you have it in nuetral or the clutch is pressed in when you start the car. i would assume their is a way to wire in the button on the pedal assembly but have never really researched it.
P.S. take out the blue box under the dash (mounted where the new clutch pedal will go) it controls the locking mechanism for the steering wheel and key.
the pedal assemblies are a ****, give the dumb guy that job it'll take a while and keep him from screwing stuff up
well i think this covers it
hope this helps, PM me if you have any questions
not to sound like a dick but this is a post i made a few months back and it took me 1 try to find it, search next time.
could someone maby add this to FAQ?
Old Oct 19, 2005 | 02:30 PM
lilriceburner
>94' Civic Si Coupe
Thanks guys...thread closed.
